Accidentally Added Hydraulic Oil to Car
Years or decades ago my brother and Dad drained the transmission of my brothers car thinking it was the engine. And added 5 QT of oil to the engine.
I am thinking my Dad was minimally involved as he would have picked up the color and viscosity of the drained lubricant. As would I have.
It was caught someway as nothing was damaged.
The 18 year old who bought my neighbor's car drove it lacking oil.
There are silvery sparkles in the oil now.
He said, "I'll just pop-in another engine".
He doesn't even own any tools.
Granted, we all have to start acquiring knowledge and wisdom at some point (hopefully). Sadly, this is a classic case of when Naivety dies on the cold hard slab real life. May thy engine rest in peace.
Funny, brought back a memory of my 'broke" buddy who lost the rear main seal in his Oldsmobile years ago.
I noticed all my old half used quarts of everything started disappearing from my garage. old Harley oil, lawn mower oil, gear oil, If that oil was not nailed down it went in his car.
I knew we had a problem when my friends started calling looking for missing oil bottles...
His leak was so bad he would leave a 4" wide trail of oil behind him. I think he used more oil that gas.
He was always welcome to my old oil but after a month or so I had to come down hard on him as he was leaving a mess in my neighborhood... He did finally replace the seal.
My truck was losing a quart of oil every 75 miles for a while. It was bad enough that I would put a metal pan under it when I was parking in parking lots or someone's driveway. The smoke trail following me everywhere was nuts!
It would drip directly on the exhaust Y pipe (which somehow still managed to rust out).
I was genuinely worried the truck would catch on fire so I finally fixed it.
Watched the boss-man run a snowblower on a 50/50 mix of proper oil and 2190 Turbine oil. It did fine. I wouldn't do what you did to my car, though, and think you should change it all out.
It was actually Air Compressor ISO 32. I did oil changes on three of my cars. At the end I topped them all off with an open jug of oil from the shelf. I added about .5 to 1 quart to each of them. I then remembered I had used that jug for some air compressor oil... I think.
Anyways if it was hydraulic oil do I need to change out the oil? Or will a half to one quart cause any real problems?
I put hydraulic fluid in engines all the time. I don't leave it in there for very long.
I had a 68 Chevy 1/2 ton short bed with a straight 292. That engine had a combo oil consumption problem.
Leaking, wore rings and had valve seals. I was young and didn't have excess cash for such things back then.
It got bad enough I was topping it off with spare 90W gear oil I had laying around.
I end up swapping it out for a 250, then a 307. Little did I know, the 307 had a hair line crack in one of the rod bolts.
I eventually found that out when the piston stayed in place and the crank rotated out of the rod cap. It was fine until the crank rotated back around and "met" back up with the piston rod.
The truck body was in good shape, so I sold it off for $400 and moved on with my life.
Two motor swaps in one vehicle was my limit.
I can resonate with that. This is the second engine in this truck. It still uses/leaks some oil but a lot more reasonable now.
But it has some piston slap and a weird valvetrain noise from the left side head on a cold start. It's tired. A previous owner overheated the daylights out of it and it was full of crusty sludge when I opened it up for the head job.
I keep looking at the rest of the truck and it's just not worth another engine. But given everything else and my own cheapness, I'll probably end up putting another engine in it at some point.
Change it....but send a sample out for analysis so we all can see. Who knows, you may have stumbled upon the next generation of Valvoline Restore and Protect+.
