AC Delco Going Metal eCore
ZeeOSix
$100 site donor 2022
PNW
Looks like AC Delco is going with a metal wire eCore center tube design. Should be interesting to see how it works out.
Center tubes don't really contribute much delta-p anyway ... unless it's a louvered center tube with barely opened up louvers like have been seen once and awhile.
Wonder if this is cartridges only, or spin-ons too? Might cut down on the crushed, twisted cartridge filters (that AREN'T Hengst made) a little.
The AC Delco video shows a spin-on.
I'm curious why they are going from nylon to metal? Seems like making it out of metal might be harder to do than molded nylon.
I don’t think so. Machinery is pretty good with making almost everything.
If you look closely that looks like a heavy duty fencing hardware. They just cut and weld together to make the tube.
It will be interesting to see the first C&P on one of these.
Then, is it really still an "ecore"? Or perhaps a mecore, metcore or metcage. What are those endcaps made of?
I rather like the current Champs Labs ACD/Super Tech ecore design. Wonder if SuperTech and AZ STP ecore will change.
That was my thought too. Can't really be a money savings, especially if they have to form the metal cage via some sort of welding process.
Maybe it's just a plastic that's chrome-coated to look like metal. You know, so that Harley owners will buy it.
Funny - I don't hear anyone whining about the lack of metal end caps ... or the nitrile ADBV ...
Seriously though, in the end, I'm sure it'll work just fine.
I wonder if this new core is in response to some other change like the filter media? The two major filter families are consolidating designs and materials across the lines.
