OVERKILL
$100 Site Donor 2021
BTW, Uncle Dave, you touched on the minimum feasible size for a nuclear facility earlier, indicating "nobody would build a 10MW nuclear plant". Interestingly enough, if you haven't been following the SMR idea, that's actually the direction things are headed (though not quite that small).
SMR's are going to be between 60 and 120MW, a small fraction of our present units. But they occupy significantly less space, with each single-unit facility requiring a total area of about 4 acres. A 90MW SMR is supposed to cost around $600 million, or at least that's the price target. The idea of standardized modularity is supposed to simultaneously drive-down cost while driving up safety and scalability. An install can use as few as one units or as many will fit in the space. This is designed to work in conjunction with the philosophy of near-point generation where power is produced close to where its consumed rather than hundreds of miles away. These smaller facilities are also much better suited to work in concert with wind, solar and hydro installs to meet community needs.
