Originally Posted By: pottymouth
Originally Posted By: IH8mush
I have sent a prominent axle builder here in the North West a sample of this grease that is considered Outdated by Toyota Sales,
Longfield, when I first presented this info on IH8mudd I was suprized at the lack of knowledge on the finer details of this design, As mention this ignorance is intentional, basically when the subject comes up, well versed Toyota propagandists "Obfuscate" this situation,
I have no dog in this fight, but I can't help but notice many statements that go nowhere like the above. So, you sent "a prominent axle builder" a sample of your grease. Who is he? What happened? I can send Roush a dirty diaper, what exactly does it prove?
I'm potentially open minded to what you have to say, but you are not providing any evidence of anything. You assert that Toyota originally used a different lubricant in these applications but have nothinbg to back it up. You also provide no independent proof that your product is superior in the application.
Seems to me it's time to put up or shut up.
Well ok I sent a sample of this grease to the biggest Toyota aftermarket axle builder in this area
Longfield, So that is a put up, I have put up sent samples to A shop in Ca called "yotamasters" no feed back to thats a put up that went no where,
I sent a sample to Christo Slee, in Colorado a Toyota shop and that was another "Put up" that went nowhere No Feedback it was so your saying to use a lube that looks like axle seal failure??
Yep sure am because more often then not it is not the problem,
It is the type of grease used by manufactures,
I sent a sample to a parts guy by the name of Kurt Williams in Utah,
While he is playing dumb I can tell from his posts and statements that he knows full well about this form of lube
Another put up that went no where
So Mr potty mouth I have put up, used this grease in closed steering axles, Fords Toyotas Dodge it does not matter all the same thing all the same parts materials used and grease all off of the same design in fact Toyota upper and lower trunnion bearings and wiper seal INTERCHANGE with the DANA axle subtle differences but the same thing
I have documented repairs on this axle, researched it, consulted with oil and grease specialists, other repair shops,
And simply put the proof of a semi fluid grease is used is in the design of the axle, the mechanical engineering involved in containing a semi fluid,
while like the Ford axle that I redid may not be designed persay for a semi fluid grease it can contain it, and will give it the same longevity,
The Main situation is a incompatible grease is speced in the manual
Proof of this is what I diagnosed in a axle I repaired, so you can see I have put up its time for these Totota folks to Put up or shut up
I have and will continue to do so,
So I have hopes, once I used this lube and worked with it, it was obvious to me why it is used in this application
And it is a simple as this would you use a #2 molybdentite disulphide lithium chassis grease for a CV joint??
No, not if you want it to last,,,,
And more proof is in the pudding old school Jeepers and mechanic mix up for these things, recognizing the need for a semi fluid grease
So I have "put up"
So I have "put up"
