Originally Posted By: XS650
AKA: If more is better, then too much is just right.
Too much is always better than not enough.
In this specific case if a 1.5 ton unit isn't able to keep the house cool, a 2 ton or even 2.5 ton unit should be installed... which sounds like exactly what happened. This 'oversized is bad' idea is silly unless the compressor is GROSSLY oversized for the system.
Originally Posted By: StevieC
House dropped from 80C to 72c (where they had it) in about an hour.
Wow, they like it hot! Thought you'd have to run the heat full blast to get a house up to 80C!
ITYM °F
ITYM °F
