It's been mild here for the past two weeks so we've not had the A/C on. Today is a bit of a warm day so I wanted to turn the A/C on and noticed that the A/C didn't kick in when it should've based on the way it's programmed. Turned the program off and switched it to A/C mode and set the temp to 75*, no dice. Turned the fan on, and that works just fine. Decided to see if I set it to heat if it would kick the heater on, no dice again. Mind you, when I manually switched to heat or cool, neither a snowflake nor flame appeared on the screen.
Sounds like my thermostat is the problem, thoughts?
