GM LT-1 5.7L 350 CID V-8 Oil used: Castrol Syntec 0W/30 (German)
Oil use interval: 2,183 miles
Mileage on engine: 95,764 miles
BLACKSTONE
CHRIS: We’re happy to report no excess bearing wear or anti-freeze was found in the first sample from
your engine, so it looks like the previous owner took good care of it. Universal averages show typical wear
levels for this type of engine after about 3,400 miles on the oil. Bearing wear is seen at copper, lead, and tin.
Aluminum and chrome were slightly above average and this could be related to the ticking sound you
mentioned, though at these levels, they aren't enough to worry about. No fuel dilution was found. Try going
to ~4k miles on the next oil.
Aluminum: 5 Universal Average:4
Chromium: 2 1
Iron: 13 21
Copper: 3 6
Lead: 3 9
Tin: 1 2
Moly: 6 64
Nickel: 1 1
Manganese:0 1
Silver: 0 0
Titanium: 0 0
Potassium: 0 1
Boron: 8 50
Silicon:15 21
Sodium: 7 16
Calcium: 1721 2131
Magnesium: 504 198
Phosphorus: 836 723
Zinc: 1081 862
Barium:0 0
SUS VIS@210: 65.3 59-68
Cst VIS@100C: 11.68 9.9-12.7
Flashpoint in F: 410 >365
Fuel%: Antifreeze%: 0.0 0.0
Water%: 0.0 0.0
Insolubles%: 0.3
I changed it with so little miles because I started hearing a ticking at idle right after switching to GC. Any ideas why the aluminum and chrome are a little high? I've switched to Mobil 1 HM 10w30 and the tick is mostly gone.
BLACKSTONE
Chromium: 2 1
Iron: 13 21
Copper: 3 6
Lead: 3 9
Tin: 1 2
Moly: 6 64
Nickel: 1 1
Manganese:0 1
Silver: 0 0
Titanium: 0 0
Potassium: 0 1
Boron: 8 50
Silicon:15 21
Sodium: 7 16
Calcium: 1721 2131
Magnesium: 504 198
Phosphorus: 836 723
Zinc: 1081 862
Barium:0 0
Water%: 0.0 0.0
Insolubles%: 0.3
