This is the sixth run of this oil/weight in this engine. 8 ounces of Maxlife Engine protector was added at the beginning of this interval. Air filter was changed in beginning of interval to Napa Gold air filter. Second UOA on this car. Driving conditions were 50/50 city and highway. Work is 3.7 miles away and 3.7 miles back home. Multiple starts a day. Oil changed with same oil/weight and 8 ounces of maxlife engine protector. I got the maxlife engine protector free after rebate. When I received free maxlife last year, they sent me $3 coupons to try their new maxlife engine protector. You can buy at walmart for 2.94 a bottle. No fuel additives used. Comparison of first and second oil analysis listed below. Same lab. Sample taken when 1/2 oil drained. Only thing changed from this sample to last is use of Maxlife engine protector and Napa gold air filter and a 700 mile longer interval.
1996 Pontiac Sunfire 2.2L/110804 miles
Exxon superflo 10w-30
3839 miles
Oil Capacity 4 qts
Make up oil 1 quart
Havoline oil filter
Visc 100 cst 11.0
Water 0
Soot 0
Fuel 0
Glycol 0
FE 0
CR 0
PB 13
CU 5
SN 0
AL 0
SI 8
NA 1
MO 150
K 0
Nitration 5.0
Oxidation 10.8
TBN 6.3
My comments: Look Ma! no iron wear!
Lead is still high and the increase in moly is from Maxlife engine protector didn't help at all. Changing air filter didn't help either although silicon is 5 ppm less than last interval. I do have some superflo 10w40 I could use that may help with the bearing wear. The viscosity is lower than previous analysis. TBN is up. could have maxlife engine protector boosted it up that high?
driving conditions were the same. As always any suggestions, comments, and insults are welcome.
First UOA:
No oil additives or fuel additive in this interval. Sample taken with 3/4 oil was drained out. Results below from oilguard
1996 Pontiac Sunfire 2.2L/106965 miles
Exxon Superflo 10w-30
3113 miles
Oil capacity 4 qts
Make up oil: .75 qt
Air filter Fram with at least 30k miles on it
Havoline oil filter
Visc 100cst 13.6
Water 0
Soot 0.2
Fuel 0
glycol 0
FE 4
CR 0
PB 12
CU 4
SN 0
AL 1
SI 13
NA 0
MO 75
K 0
Nitration 8.8
Oxidation 3.5
[ October 22, 2004, 01:28 PM: Message edited by: Cutehumor ]
3839 miles
Oil Capacity 4 qts
Make up oil 1 quart
Havoline oil filter
Visc 100 cst 11.0
Water 0
Soot 0
Fuel 0
Glycol 0
FE 0
CR 0
PB 13
CU 5
SN 0
AL 0
SI 8
NA 1
MO 150
K 0
Nitration 5.0
Oxidation 10.8
TBN 6.3
First UOA:
3113 miles
Oil capacity 4 qts
Make up oil: .75 qt
Havoline oil filter
Visc 100cst 13.6
Water 0
Soot 0.2
Fuel 0
glycol 0
FE 4
CR 0
PB 12
CU 4
SN 0
AL 1
SI 13
NA 0
MO 75
K 0
Nitration 8.8
Oxidation 3.5
