Okay, for all who saw my previous UOA using Golden Spectro, you will see that this report eases my mind and then some.
code:I would have expected much more than 18ppm iron simply from oil in the motor that did not drain during the change. Needless to say, I'm very excited by this report. Things to note: this was my Auto-RX cleaning phase, so I had 7 ounces of Auto-RX in there. Also, I put in 3.5 ounces of Lube Control. I was also using Fuel Power at the same time.MIles on Unit 32179 Miles on Oil 680 Cu 8 Fe 18 Cr 1 Ni 1 Ti 0 V 0 Ag 0 Pb 1 Sn 0 Al 5 Si 3 Na 3 K 2 Mo 12 B 16 Ba 0 Ca 2650 Mg 76 Mn 0 P 1266 Sb 2 Zn 1414 Visc @ 100 12.6 PARTICLE COUNT >5u 34247 >10u 1297 >15u 104 >20u 35 >25u 17 >50u 2 >75u 1 >100u 0 ISO 22/14 Particle Vol. 3 Ferrous Debris 15 Antifreeze Neg Fuel Neg Water Neg
