'94 Grand Am 4T60-E NEO ATF 15618 OCI 192618 total
northern Alabama
Code:
ATF used NEO ATF
Sample Date 16-Feb-2009
Miles on oil 15,618
Miles on car 192,318
Make-up oil None
Filter: AC-Delco
% tested fluid: 79%
Lab: Dyson
Wear Metals:
Iron: 192
Copper: 63
Tin: 0
Lead: 23
Chromium: 0
Nickel: 0
Aluminum: 8
Titanium: 0
Silver: 0
Additive Metals:
Calcium: 462
Magnesium: 7
Zinc: 37
Phosphorus: 281
Barium: 1
Molybdenum: 0
Antimony: 0
Contaminant Metals:
Silicon: 8
Sodium: 17
Boron: 188
Potassium: 0
Vanadium: 0
Physical & Other Tests:
Viscosity 40C: 23.5
Viscosity 100C: 4.9
TAN: 0.73
Flashpoint: 325
Oxidation: 57
Nitration: 5
KF Water: 728
TBN: 0.6
Fuel: 1.25
Soot: 6.54
Glycol: 0
VI: 136
Sulfate: 58
This is the 4-speed auto with the infamous 3.1L V6. The transmission cooler lines were leaking so I just dropped the pan & changed it along with new lines.
Neo is a diester based oil that starts out thin. I am considering refilling with Royal Purple Max-ATF. It starts out at 7.5 cSt but will it shear badly? I may run only 15-20k miles again & do a UOA. I can't imagine it being this low in that time frame.
Current filter:
Previous OCI filter (similar UOA results):
You've gotta be making up that 2nd picture... how do you still have a transmission left, all your pieces are in the filter?
No fakes here. The car still shifts well. Original thread with pictures
Steve,
NEO is just too thin IMHO for this ol' car. I mainly tried it out of curiosity b/c I didn't have the guts to try it on my Honda AT first. But, I agree that it is a good (ahem pricey) fluid.
I assume the debris in the filter is gasket material? The fluid itself looks nice and "cherry red" still. I'd think you could go longer on that fluid. I went 60K on Mobil 1 in my 4T65-E and it was still red and shifting nice. I plan on doing 75K on the current fill of Mobil 1. I also add Lubegard red.
It appears that may not really be the case with the physical tests.
Typical Characteristics:
Density at 15°C, g/mL: 0.853
Viscosity at 100°C, mm2/s: 7.7
Brookfield viscosity at -40°, cP: 11,500
Flash Point (PMC), °C, min: 180
Phosphorous, % weight: 0.022
This really makes the final viscosity result disheartening & all the more reason to change fluid & move on. That is a lot of shearing.
