My 1994 Camry 4 cyl finally died at 181K. Died while driving slowly. No even hint of catching as engine is turned over. Nothing obvious under the hood. Timing belt has 60K maybe. Gas is at 1/2 tank. Ideas?
Quote:
Anyway its a Toyota and should not easily break.
Quote:
Rotor and cap and wires were replaced awhile ago so they only have maybe 10K miles. I am hoping (always) for some thing simple as I do not want it to be timing belt or fuel pump, although this car does have an access panel under the read seat for the fuel pump I think . Anyway its a Toyota and should not easily break.
Quote:
i had the same exact problem with my 92-died out of nowhere- had to have it towed. Wound up to be the ignition coil
Quote:
You are obviously unaware of Toyota's reliability issues, especially as of late.
How old is the battery? The only time either of the vans in my signature ever failed, it was an internal battery problem.
