Slight setback. Was going to replace the oil sending unit and that danged "brass" elbow fitting/adapter broke off in the block. Fortunately, I was able to get the broken threaded portion out of the block fairly easy. No one locally sells a replacement, so I had to mail-order an aftermarket unit. On a happy note, priming the oil pump worked, as I had around a half-qt or so squirt out onto the back of the engine/trans and floor, lol.
While I'm waiting for the part, I adjusted the rockers as they were quite loose. As it stands right now, I'm not 100% convinced I've resolved the knock issue, as It could still be wrist pin related as some have mentioned. If that turns out to be the case, it's back to the drawing board. Hopefully, I can fire it up by end of the week and find out.
Yeah, its made out of some type of crappy pot metal, same material for the coolant hose quick disconnect IIRC. Those things snap just looking at them funny, they actually make a specific extractor tool for that job.
