Just Dropped In
- Joined
- Jul 16, 2024
- Messages
- 129
Removed 4 front bearings today. Main bearing #1 is kinda rough (far right in pic), the journal has some scoring too. Might be able to work that out a little (??). Rod bearing for piston #1 has a little more wear than #2. Main bearing #2 is not too bad, and the journal for it is ok. So, do I fix it the best I can and see what happens, or pull for a rebuild. My three options are: 1: fix/repair. 2: Rebuild 3: Replace with new long block. There are no rebuilders in my area (podunk rural). Anyway, here's a pic. from Right to left: Main #1, Rod #1, Rod #2, Main #2:
