ls1mike
$50 Site Donor 2025
Ok 86 3.8. No spark out of the coil. 9.8 volts to the coil when cranking. Here is the kicker When you turn the key from run to start the spark tester will light then once the car starts turning over (key in the start position) no light in the tester. When you go from start to run, quick flash of the spark tester then nothing.
Any ideas?
Any ideas?
