It's likely the extended oil changes throughout it's life have lead to sludge/varnish.Vehicle: 2016 MB E350, M276 GDI, ~195K miles.
Oil used: Mobil 1 0W40, Mann Oil Filter
Length of Interval: 11 months and ~18,000 miles. OEM service interval is 10K
Prior to this, all oil services have been performed with a 229.5 approved oil at 10-14K mile intervals.
My plan is to:
Replace Engine oil and filter with Mobil 1 0W40 and new filter.
Add two 500ML bottles of Liqui Moly Pro-Line Engine Flush. Idle engine for 20 minutes.
Perform another oil and filter change, this time with HPL Euro 5W40. Hopefully he comes back in 10K, but he probably won't.
Any better ideas?
This is it. No need for any LM.I wouldn't do anything special. Change the filter and fill it up with spec oil.
I mean $16 vs. $27 is enough for me considering the short use.10w-40 generic may be only a few bucks cheaper for a synthetic. The referenced Mobil 1 is $27 for 5 qts. at WalMart
Change oil & filter,Any better ideas?
You are dealing with someone who doesnt care as much about the car as you do, you cant fix him never mind the car. Change the oil with the M1 and send it down the road, no flush. Flushing it should have a shorter oci afterwards in case it loosens up a lot of crap.He doesn't want to come back for at least another 10K.
I was going to say… my 2004 Saab allowed 24 months and 24k km (with a computer to actively reduce the actual range based upon use).I think I will skip the LM snake oil and just do two oil changes.
Looks like in Europe -- the interval is 25,000KM/1-yr, which is 15,625 miles. I guess he isn't as overdue as I thought.
(Manual is for a 204 chassis but that platform also has the 276 engine.)
You must have missed that it's not his car and the owner routinely goes close to this long for intervals. He can't force the owner to return for early/extra oil changes.Do 2 immediate engine flushes, and then shorten oil change interval permanently to 5K (4k would be better) using above oil,
and do an engine flush during the next 5 oil changes. Then set a goal to drive the car another 200k miles.
Really, really looking forward to this.Sure, I'll take a sample.
