I'm getting old, and no longer able to crawl under my car to change oil. So I've decided to rethink my maintenance routine. My plan is to change oil based on season, rather than mileage/time.
I have a new(ish) Ford hybrid, and as far as I can find the 2.5 engine is not GDI. I live in a hot, arid part of CA where cold is 35°F, but hot is 115 at times. My truck is 14 months old, with 10k miles on it, and has had 2 oil changes, with Costco/Supertech 0W-20. I'm not comfortable using that oil in the extreme temperature months, so I plan to change oil twice annually, with one from Nov. through March, 5 months, using 0W20. Then 10W-30 the remaining 7 hot(ter) mos. I talked to the local Valvoline oil version of Quik-Lube, and they charge $45 labor if I provide oil and filter. Also check under for any obvious problems. My thought is to use Mobil-1 EP 5W-20 for the winter run then 10W-30 for the summer. HPL was on my mind but the price puts it a little out of the budget, esp. with shipping.
A couple questions: would ESP be more suitable, although to me it looks like the main advantage is lower SAPS. Mobil is always available at my local Walmart, so most any of the other brands for this particular scenario would probably be fine. Not trying to overthink this, I could probably go with a cheaper oil but a $10 difference twice a year is not a problem.
Anybody???
