"I could care less what your brand loyalty is; I am simply try to give info so you guys can make an informed and educated decisions."
It's not a question about brand loyalty, it's a basic warranty issue. Also, we appreciate your knowledge, and appreciate you taking the time to educate us, that's why we're still asking questions like 'why don't makers label or spec synchromesh as GL-4 ?'.
Below is some info on Syntorq;
http://www.high-impact.net/nv4500.htm
Additional Info: Here is the response to an inquiry that was sent to Castrol USA about where to get Castrol Syntorq in Europe: "Castrol TAF-X 75W-90 GL-4 gear oil is made in the U.K. and sold only in Europe. However, the equivalent in the U.S. is Syntorq LT. Having said that, Syntorq LT SAE 75W-85, API GL -4 is a premium high performance, synthetic gear lubricant for synchronized manual transmissions. The all new "clean slate" approach enables Syntorq LT to provide consistent performance and durability under the most severe operating conditions due to its unique polymer free formula. It has been designed primarily as a problem solving gear lubricant for manual transmissions to provide reduced gearshift effort at low temperatures. Syntorq LT is available through General Motors (Part #12346190) and Chrysler (Part #4637579) dealerships. Please contact your local dealership."
http://www.gm-diesel.com/diesel/vbull/showthread.php?t=9722
I have a 97 K2500 with manual 5 spd (MW3 = NV4500 I think). The shop manual specs Castrol Syntorq or GM P/N 12346190.
Why brand specific? Is it synthetic gear oil or semi-synthetic? What is the viscosity? What is equivalent? What is the Amsoil equivalent?
http://www.napcltd.ca/forms/oil-guide.pdf
http://quad4x4.com/NV4500FAQ.htm
What lubricant should I use and were can I get it?
Castrol Syntorq LT® 75w85w GL-4 rated, low temperature, synthetic gear lubricant is the only factory approved lubricant for NV4500 series transmissions. Some other lubricant manufacturers such as Amsoil may have products that are compatible. However, we have yet to see any other lubricant match the specifications of Syntorq LT®.
Castrol Syntorq LT® is available in quart bottles from Dodge dealers (p/n 4874459) and GM dealers (p/n 12346190). Castrol distributors offer factory sealed 16 gallon drums, plus some repackage the oil in 5 gallon pails. We sell Syntorq LT® in two quart jugs.
