I would like to revive or pursue this discussion further: https://bobistheoilguy.com/forums/threads/specs-on-bmw-mtf-lt-4.309550/
I have a 2012 Mini Cooper that fell into my lap and buying some Amsoil to replace all the fluids. However, I get to the manual transmission oil and Amsoil says they don't have it.
Based on what was discussed in the linked thread, it seems like Red Line MT-90 might be a good option. I am fine with that. Also curious if either of these Amsoil options are also a good choice.
1. https://www.amsoil.com/p/amsoil-75w-90-manual-transmission-transaxle-gear-lube-mtg/
2. https://www.amsoil.com/p/amsoil-5w30-manual-synchromesh-transmission-fluid-mtf/
(1) To determine the correct gear box oil, check the sticker on the transmission. Manual gear box oil MTF-LT-3 is marked with a blue sticker. Manual gear box oil MTF-LT-4 is marked with a yellow sticker. Do not mix MTF-LT-3 with MTF-LT-4. (1) To determine the correct gear box oil, check the sticker on the transmission. Manual gear box oil MTF-LT-3 is marked with a blue sticker. Manual gear box oil MTF-LT-4 is marked with a yellow sticker. Do not mix MTF-LT-3 with MTF-LT-4.
