code:
2001 Crown Victoria LX
Miles on car: ~27,326
Miles on oil: ~6,304
Make-up oil: None
Filter: Mobil 1
Oil: Mobil 1 SS 5W-30
Oil was used between June 6 and August 26 in NYC weather.
I thought the report would be worse since I had
just quit smoking a few weeks after putting this
oil in and have been driving like a maniac ever
since. Lots of WOT with the A/C on, lots of
gridlock, gridlock, traffic, traffic. Even
though the oil thickened up above a 30WT, the TBN
was high and wear was low, so maybe I'll try
another 1,000 miles on the next interval? I have
no idea what's up with the silicon levels. The
Fram air filter is 7,000 miles old, pretty clean,
seated properly and the airbox is tight. It's
weird. Discuss.
27,326 on car 21,100 on car
6,304 on oil 5,100 on oil 4,300 mile average
Aluminum 3 3 5
Chromium 1 1 1
Iron 20 14 22
Copper 7 3 11
Lead 1 1 2
Tin 0 0 1
Molybdenum 74 76 31
Nickel 0 0 1
Manganese 1 1 1
Silver 0 0 0
Titanium 0 0 0
Potassium 2 3 0
Boron 110 143 45
Silicon 27 26 13
Sodium 8 8 7
Calcium 3013 2756 1768
Magnesium 27 35 450
Phosphorus 737 775 787
Zinc 855 874 971
Barium 0 0 1
SUS @ 210F 65.9 60.6 55-62
Flashpoint 405 420 >365
%Fuel
%Antifreeze 0 0.0 0
%Water 0 0.0
%Insolubles 0.3 0.2
TBN 5.7 4
Comments:
JOHN: Why is silicon reading so high in your
engine? We don't know. If you know it's coming
from a non-abrasive source, such as an anti-foam
additive or a silicone-based sealer, then we
won't worry about it. Let us know. It doesn't
really look like abrasive dirt, since wear looks
okay. The TBN read 5.7, showing plenty of active
additive remaining in the oil. Insolubles (oil
oxidation due to heat, use and blow-by) were low
at 0.3%, showing good oil filtration. Other than
the mysterious silicon, we have nothing new to
report. You could go longer on this oil.
[ September 24, 2003, 12:18 AM: Message edited by: johnicon ]
