Car: 2004 Hyundai Elantra
I've noticed as the car has aged and miles increased that the MPG which used to be 29-32 had fallen off to 25-28. I was keeping up with the filter changes etc. myself.
At 66k miles I finally had the dough to get it in for the timing belt change. During the phone conversation for the appointment, I asked if they had any ideas on why the mileage has dropped off. The service rep (as he should) said the 60k maintenance work would probably help. I agreed to let them do it and I took the car in.
I got the car back, and the first tank of mileage was 21.5 MPG. I ran another couple hundred miles expecting improvement. The best I was able to get was 24.8 MPG and that was on the highway cruising at 60mph for 100 miles.
So I call the dealership back to ask what they think could have happened. The rep basically told me that "if the check engine light isn't on, there's nothing wrong with the car". I asked what things could have happened to drop the MPG over 30% in one day (during a maintanence appointment that was supposed to improve my MPG). The only thing he said could have happened was my tires might have been over inflated, to which I replied "and that could make a 30% difference in my MPG?" No response.
So he will not look at the car (because the "check engine" light isn't on) because "there's nothing wrong with it".
Is this normal? Getting a car serviced for "low MPG" and it being returned to you getting 33% LESS?
I'm just confused. For a 2.0 liter engine that used to get 30+MPG, I think I should expect to remain close to that.
The 60k maintanence was around $560.
Any suggestions????
-7
Any suggestions????
-7
