That's what Hyundai Kia calls severe use oci. And it still didn't solve the problem. So called tech bulletin that was put out to solve the GDI crisis.And 203 oil changes equals 3k mile intervals
Sounds like one of those dealer warranties where you have to buy overpriced preventative maintenance from them and only them. Worked out for this guy though.Wow what a turd. An engine every 66k and a trans every 150k. And 203 oil changes equals 3k mile intervals and the trans was flushed every 30k too so lots of maintenance.
Dude got a 10 year, unlimited miles warranty, then bolted after the ten years, LOL. Maybe atikovi's mall cruiser looks like the sane option...
True but I can't imagine the dealer oil and fluid changes were reasonably priced.Sounds like one of those dealer warranties where you have to buy overpriced preventative maintenance from them and only them. Worked out for this guy though.
Possibly incorrect. A normal owner may not be running the engine hard for extended periods of time. These engines are sensitive to low oil viscosity. An engine operated for extended periods of time, at high oil temperatures, which can result in low viscosity will experience bearing problems. I don't have any inside info, but "if" I were to guess, I'd say a string of rod bearing failures were the reason for the engine changes.I find this hard to believe. This vehicle is driven 60,000 miles a year which would mean few cold starts and perhaps a lot of highway driving. Frequent servicing indicates proper maintenance. If these engines failed that often under circumstances like this, they wouldn't last 20,000 miles with the average owner.
If an engine can’t handle highway use, at factory oil viscosity and non-ridiculous ambient temps & speeds-that manufacturer needs to hang it up or redesign their junk. Hyundai/Kia does seem to have a few engine durability “issues”!Possibly incorrect. A normal owner may not be running the engine hard for extended periods of time. These engines are sensitive to low oil viscosity. An engine operated for extended periods of time, at high oil temperatures, which can result in low viscosity will experience bearing problems. I don't have any inside info, but "if" I were to guess, I'd say a string of rod bearing failures were the reason for the engine changes.
A normal owner probably does not get the oil to very high temps.
