I have a "work in progress" for the last several months, a 2010 Ranger 800xp EPS, so far it's morphed into a stretched, widenend, lifted, 31" tire'd 70hp bush stomper
I've had the engine built up from the stoclk 46hp to 70ish (literally took it out of just one 40mile ride to make sure all is functioning fine and tore the brand new motor apart heheheh!) with a 7,000rpm cam, 11:1 pistons, bored TB, programmed ECU, ported head with valve job, boondocker fuel controller and a few other goodies. I have a guage cluster to monitor the machine's functions, a properly working fuel guage, voltmeter, engine temp, oil pressure, and a wideband air/fuel meter (awesome for dialing in jetting).
I was told this motor will produce more heat than the stocker, I expected this and I'm running Amsoil 0w40 atv oil, but I've noticed alot of oil pressure drop once fully warmed and running hard. Cold pressures are 40psi at idle and climb into the 50-70psi range under throttle, but when screaming along it's in the 25-30psi range, I'd like to run a thicker oil.
Klotz has a power sports 0w50 but I'm having a [censored] of a time getting it. I have access to Ford Racing 5w50 which is more like a 5w62 (100c visc rating of 21), can I run this stuff in my motor or is 25-30psi nothing to worry about with a UTV? Also to add, I have no cooling issues, coolant temps are good.
Thanks eh!!
Thanks eh!!
