Originally Posted By: edyvw
Originally Posted By: JDM396
Hey guys, I have a 2016 F150 3.5 Eco. I've got a ton of Castrol Syn 0w40 and 5w40 laying around. I've seen some of the UOAs on this motor and it shears some oils down a good amount. From what I'm reading here the two aren't that much different? Or am I incorrect? Some local guys are running 0w40 no problem. Just curious if I could use the 5w40 too.
Regardless of outside temperature, you can use 5W 0r 0W. In all 48 lower states you can use 5W easily.
However, I would stay away from Castrol 5W40. it is not even close to Castrol 0W40. 0W40 meets MB 229.5 requirement which means it leaves less deposits on. It is so called true synthetic, PAO based, while 5W40 is HC oil, and not remarkable one by any measure.I used 5W40 in my Passat 1.8T and it would create lifter noise after 4K like on clock. 0W30 or 0W40 castrol never did it, and so far they have been smoothest in my VW applications of all Euro gas oils.
Also, 0W40 is thinner on 100c, but has same HTHS as 5W40, compliments of much better base stock.
Thanks, I'll stick with the 0w40.
