Originally Posted By: fsskier
Why would I want a vehicle that needs towed every winter when skiing the mountains and morning temps reach -40, or lower?
Hint: you miss a day of skiing, and there are many more failed vehicles than there are wreckers.
I have no idea what you're saying. There are mountains in Iowa?
LOL. Who would run 10W30 when it's -40? For that matter, who would run 5W30?
Another poster said "most wear occurs at startup, not during warmup" and yet the very complete tests published by GM and
Mobil - and others - show that piston/cylinder wear is far greater during warmup. Once the oil is hot, and viscosity reaches "10" the oil flying off the rod bearings and up onto the cylinder wall is like a shower, and wear is nearly zilch.
Thick (cold) oil hardly flows out of the rod bearings at all (remember, .002 clearance) and the cylinder walls run with very marginal lubrication until the oil thins.
Well, show me the papers. I remember seeing an older paper on SAE30 showing it protected better than 10W30 during startup. I couldn't find the paper here, but I know I've seen it.
Besides that, consider that a typical Jeep club trail ride consists of driving a bit, winching, high RPM in low range on tough obstacles, stop to extricate someone, start and go again(still in low range), etc. My engine hardly gets to operating temp, nevermind the oil getting hot. So if "far greater wear" occurs during warm up, where was all the wear in the last two used oil analysis of my 2.5L Jeep trail rig running SAE30 (the beefy 12.1cSt Delo) or 10W40? How about when I was sitting on my side waiting to get pushed back over?
There is no question that 5W30 flows better when it's cold out. That's a no brainer. The idea though, that thick oil is the devil and that my engine will pop if I don't run 0W20 doesn't make sense. I'm not against thin oils (I use 5W20 in my F150), but thick oils have their place too.
Originally Posted By: grease_monkey
Personally I wouldn't run rotella 5w40 in a gasoline engine especially if it was manufactured from 2000 to present mainly because of the additive package in it. Rotella is a diesel engine oil so the additive package put in there would not be designed to be used in a gasoline engine.
Sorry man, that just isn't true. Rotella 5W40 is SM rated and perfectly fine for gasoline use. People (including me) have been running HDEO's for years.
