Originally Posted By: doitmyself
modularv8,
Thank you for sharing your experience with us. Excellent presentation and what BITOG is/should be all about.
In this statement of yours:
Quote:
In my experience from reading many used oil analysis, I have found many reports showing Motorcraft 5w20 shearing to about 11% (from 8.7 cSt to ~7.7cSt), the same goes for conventional 5w20's....... Here is the problem, OEMs have specified a 2.6 cSt minimum viscosity for HTHS 150C. Fresh oil can accomplish this but after some point in the OCI, the engine is now operating with oil only capable of 2.45 cSt.
Every industry study I have read and commentary from engineers have been that below 2.6 cSt (HTHS 150C) you begin to increase wear beyond normal.
Is this increased wear applicable to all engines, or just those with VCT?
In general, not just VCT. But I am talking about engines not designed to operate on HTHSV below 2.6 cSt. Right now, I am not aware of any production vehicles specified to run on HTHSV below 2.6 cSt.
Quote:
If all engines, then people running longer OCI's on 5W20 should maybe check their cSt, correct? Also, I wonder if the increased wear is offset by less cold start wear to the point it is insignificant.
Thanks again.
Possibly, I don't know. But there are many reasons why an oil can enter the yellow and red zone. Fuel dilution and excessive shearing are the two main ones I can think of that will put an engine into these caution zones when starting from HTHSV of 2.6 cSt.
For those who are interested in what I am talking about, here are some sources.
HTHSV Piston Ring Wear and Fuel Savings Correlation
New Base Oils Pose New Challenges - Figure 4 (last page)
"The move from oils that have High Temperature High Shear Viscosities (HTHSV) of 3.5 mPa.s to oils with
a HTHSV of 2.9 mPa.s is not expected to have a major effect on engine durability for modern gasoline
engines. Indeed, some of these engines may well be running on 2.9 mPa.s oils in the USA or Japan.
Durability may well be of more concern when moving from oils with a HTHSV of 2.9 mPa.s to lower
values (e.g. to 2.6 mPa.s)."*
*Improved Fuel Efficiency by Lubricant Design : A Review
R.I. Taylor & R.C. Coy
"Toyota stated a concern that engine wear might well increase if HTHS viscosity dropped below the range of 2.3 to 2.4 mPa·s"**
Is SAE 5W-5 in Our Future?
And there are others that report even higher possible levels (on the order of 30%***) of wear not visible by used oil analysis. Having said all that, engines specified by the OEM to run on 5w20 have been designed or tested to do so. However, the minimum HTHSV by any OEM is still 2.6 cSt. Does it make a difference when an oil shears into the 2.5 cSt and below range for HTHSV? Probably How much? I don't know, but I'd stay away from it. As far as the fuel economy benefit of 5w20, most can be gained with a 5w20 oil in the HTHSV range of 2.9 cSt and below. So a 5w20 at 2.8 cSt would be ideal, while staying out of possible trouble.
Optimum Viscosity Grade
By the way, I like the lower viscosity grades (5w20). Some engines are designed to need the extra flow and works great in the winter. I prefer a shear stable (synthetic) 5w20 oil with a minumum HTHSV of 2.75 cSt. Without having to mix my own oil, right now Mobil 1 5w20 looks to have the right formulation.
And as always, run what you like in your engine.
