5w20 oil choices
In the shop
Good evening folks. Thinking of using a 5w20 next in the Camry. Probably just do 5k oci also since i had to add just shy of 1 quart over a 10k oci with a High Mileage 10w40 oil. Valve cover gasket has slight weep on corner but not terrible. Im thinking of Quaker State Conventional 5w20 or Quaker State Ultimate Durability or even Super Tech 5W20 Conventional
What say the BITOG faithful
The price for Super Tech synthetic being $15.88 for the 5 quart just is soo hard to pass on. Same price for the ST High Mileage Full Synthetic -- try either one 5W20 flavor.
Dale
Dale
Yeah, looked online at my store and it went up to $15.98. May go with that
Originally Posted by mclasser
Why the jump from 10w40 to 5w20?
Only used the Mobil 1 10w40HM cause it was $1 a quart
Besides, i dont have much of a stash of oil, just filters
Maybe the 5w20 will help consumption or who knows
You may also want to compare Mobil Super full synthetic, and Castrol GTX Magnatec full synthetic. Those are in the same price ballpark as lower priced synthetics. All are good oils.
I would not worry about weeping valve cover gasket it is no biggy you could go another 100,000 like that. By the time you need major maintenance they would replace that gasket then anyway.
Adam how long ago has it been since you put that Pennzoil Platinum 5w30 and TG 4967 in and on your Camry?
But I'm curious what that weeping is going to do with that 5w-20.
Winter coming?
Yep, last winter the Camry started fine even in -25F in central PA.
Yeah, I'll have to see if Rural King has Mobil super Syn still as last time it was cheaper than any other place.
Originally Posted by 53' Stude
Quaker State Conventional 5w20 or Quaker State Ultimate Durability)
One of those
You may notice less oil consumption running a 5w20. Mobil 1 or valvoline high mileage would be my choice. If you have NAPA auto in your location NAPA high mileage is same as valvoline rebottled.
If you're sticking to less than $20 for oil, the Quaker State Ultimate Durability is likely the best bet. Based on consumption, I'd have no qualms running it 10k easy.
If you go up to $25, PP or Valvoline FS with Maxlife a great choice too!
Originally Posted by Zee09
Chevron Supreme
Good moly and boron
Chevron Supreme is a great inexpensive conventional oil. Would be my first choice if it's available in your area, otherwise try Citgo (Mystic or Harvest King in some areas) or Phillips Shield (used to be TropArtic). ST is not a bad oil, but the aforementioned three have given me great UOA results.
Might be good for those cold if it ever gets cold starts up there in eastern PA! I'm a fairly big fan of Magnatec 5W20, but there's other good ones, MaxLife in either Full Synthetic or blend, even Valvoline conventional/Daily Protection did well under heavy use/abuse in the company Transit.
Im in southwest PA near West Virginia border. I ended up getting Super Tech 5w20 conventional as Valvoline conventional os $19~ now and no 5w20 Valvoline Syn. Also wal mart out of stock on 5w20 Super Tech Syn and high mile syn
For 5k oci Super Tech will be fine i think
Originally Posted by dave1251
Supertech High Mileage would be my choice.
I use this in both cars.
8K or so change with a Fram Ultra filter.
Neither cars engines have blown up yet.
Temperature swings in Denver from 100 degrees to minus 20.
