Quote:
my personal mechanic suggests sticking with 5w-20 year round due to the closer tolerances and tight oil pathways in Hyundai's newer motors. Not sure if that's fact or myth.
Myth. As stated above, tolerance is the allowable error in the dimensions. Your mechanic probably meant clearances, and how does he know?
I'd use an xW-30 in your heat. Other things equal, higher viscosity gives higher film strength in the bearings.
That said, a gas turbine, really hot, uses an oil that is about 5 weight. I'd still use the xW-30.
