5w-20 is always a highly debated topic around here.
Or in best case, performed a "tear-down".
A mustang, w/slicks, produces alot of engine stress "off the line".
High RPMs typically don't cause oil related problems given there's enough pressure. But extended high RPMs/speeds could heat a 20 weight to beyond it's limit IMO. 5.25 cSt is considered the minimum safe viscosity; for a 20 that happens at 212*F, a 30 at 257*F and a 40 weight at 302*F.
An other type of abuse is "lugging". This is hard to achieve without a manual trans, and/or towing an extreme load. And it could IMO give 20 weight a problem(low HT/HS).
FWIW,
I say the 4.6L in the stang is generally shown a harder life, given that most small work trucks/SUVS are automatics and that Mustangs are more likely to be "beat on" for any length of time.
I agree.quote:
The common used oil analysis will show that the engine is fine, however, I really wonder what other things would pop up if you had a detailed more expensive UOA done.
There are different types of abuse.quote:
Sorry, I have a hard time buying that your mustang sees more abuse that any mod motor in any Ford Truck in general.
FWIW,
