I've got a 97' Mustang with the 4.6, it recommends 5W-30 but I've been tempted to try the motorcraft 5W-20. How far back has Ford okayed the use of 5W-20 in their vehicles? Thanks
quote:"Oh ye of little faith"
Originally posted by Schmoe: But first and utmost....WHY do you want to go with a 5W-20 in the 'Stang????? A 5W-30 would be the absolute minimum I'd run in a V8.
quote:OK, I guess I just don't understand the Midwestern dialect
Originally posted by darkdan: Exactly, so kick the dino the curb and grab a group IV 5w30. =)
quote:So run it longer than 3k! Problem solved.
Originally posted by 97flairside: well i just picked up 6 quarts of the 5w20 motorcraft from wallie world. Im going to give it a shot. Been using m1 full syn. 10w30 then swtitched to 5w30. Getting a little expensive at 3000mile int.
quote:Sounds like your defense of MC 5W20 is primarily based on "good UOAs." Besides that, all your doing is falling into teh same "sin" catagory as me...expressing personal experience. my mustang has drag radials on it during the summer weekends. It also can run the drag strip at a higher/faster speed than a number of mustangs out there. I have a FRPP 4.30 ring and pinion, Moser 31 spline axles, Eaton Posi set-up for teh rear-end alone, which revs teh engine higher at all RPMs. lets not get into what I've done with the rest of the car. In short, it's set-up for naturally asperated drag racing, which in fact does put more stress on a car engine that or a normally driven/towing truck. As I mentioned before, I'm not saying that 5W20 is goign to cause problems, but after all the money I've spent on my ride, there is no way that I will put a 520 weight in the heart of it all.
Originally posted by 02supercrew:quote:How sure are you that it was the oil it self? Dont suppose you had a UOA done on the oil to actually determine if it really was the oil? And if it was really the oil, there would be a whole pile of cratered motors as a result from that bad batch of oil that your friends motor got. Seems to me QS had something like this happen way back in the day. Sorry, I have a hard time buying that your mustang sees more abuse that any mod motor in any Ford Truck in general. I'm currenty looking at 5 V-10 service body trucks that all have over 250K on plain ole MC 5-20, and that's not counting the other 15 various mod motor trucks we have, all have more than 70K each. Not to mention all the good UOA's of MC 5-20 on this board.
Originally posted by mf150: I just had a friend blow a "bulletproof" 4.6L "PI" mustang engine (2002 GT). The oil that was in the engine when it blew: 5W20 weight Motorcraft. 20 weight may be okay for conservatively driven street vehicles, but if you are going to put any stress on that motor, go with a 30 weight.
quote:I don't blame you one bit. Even though I run 5w-20 exclusively, I too would think long and hard before I ran it in your car.
Originally posted by mf150: my mustang has drag radials on it during the summer weekends. It also can run the drag strip at a higher/faster speed than a number of mustangs out there. I have a FRPP 4.30 ring and pinion, Moser 31 spline axles, Eaton Posi set-up for teh rear-end alone, which revs teh engine higher at all RPMs. lets not get into what I've done with the rest of the car. In short, it's set-up for naturally asperated drag racing, which in fact does put more stress on a car engine that or a normally driven/towing truck. As I mentioned before, I'm not saying that 5W20 is goign to cause problems, but after all the money I've spent on my ride, there is no way that I will put a 520 weight in the heart of it all.
quote:I don't blame you. I would not run 520 weight either. In fact as adventuresome as our Australian friends are in using thick motor oils I dont think they've gone past 70 weight
Originally posted by mf150: As I mentioned before, I'm not saying that 5W20 is goign to cause problems, but after all the money I've spent on my ride, there is no way that I will put a 520 weight in the heart of it all.
