Is Mobil 1 any good for the rear gears and 4x4 differential in a Dodge Dakota?
This is the stuff they sell at Auto Zone. If not , any other suggestions? How are you guys going about changing fluids? I was under there looking around and I only found 1 plug on the gear box. One guy suggested that I take it in and have the plate removed and cleaned and replaced with a new seal. Another guy suggested that since my truck is brand new, remove the plug and try to pump the stock fluid out with a squeeze pump and hose.
He tells me that Dodge uses quality gears in their trucks, but the oil they use is crap!
What should I do? My truck has 4000 miles on it! Thank You again.
