4x4 and rear gears fluid questions (Dodge)
USA
Is Mobil 1 any good for the rear gears and 4x4 differential in a Dodge Dakota?
This is the stuff they sell at Auto Zone. If not , any other suggestions? How are you guys going about changing fluids? I was under there looking around and I only found 1 plug on the gear box. One guy suggested that I take it in and have the plate removed and cleaned and replaced with a new seal. Another guy suggested that since my truck is brand new, remove the plug and try to pump the stock fluid out with a squeeze pump and hose.
He tells me that Dodge uses quality gears in their trucks, but the oil they use is crap!
What should I do? My truck has 4000 miles on it! Thank You again.
i have a 98 expedition 5.4 l also has a locker 3.73 axel i chaged the fluid today this big rear end takes a 75w-140 and i used redline high performance it is 100% synthetic >gl-5 and > gl-6 rated it is absolutely the best also synergyn's syngear ll is just as good ... i went to look at the mobil 1 75w-90 and it says on the bottle only gl-5 rated and the additive is a full synthetic but there is alittle asterest next to it and says exclusive of carrier oil..so this is really not 100% like red line and synergyn
"asterest next to it and says exclusive of carrier oil..so this is really not 100% like red line and synergyn"
And that matters? The mobil product is pretty good. I have used it in 5 trucks now with good results. I change it every 50k in my Dodge 2500 although there is no way it needs it at this interval.
[ February 01, 2003, 11:12 PM: Message edited by: blano ]
Are you positive this is not the case on the two others also they just did not list it as such. The carrier oils are in the additive package I believe.
yes the other two i mentioned did not say that and i know for sure redline products are all 100% synthetics no petroleum pructs in their oils or tranny fluid....now mobil told me that in all their synthetic oils there is no protroleum produvts in any of their synthetics.
