gathermewool
Site Donor 2023
Looking for a high quality, last-a-lifetime cross lug wrench, non-collapsible.
For whatever reason I've always like removing and installing my wheels by hand, following an installation with a torque wrench. I've always used the hobby shop's cross lug wrench, but I've been busy the past two times I've swapped tires and had to squeeze it in out in the condo parking lot, using the OEM wrench, which really sucks.
19mm is very close to standard 3/4"; however, I feel like the universal lug wrench the shop had wasn't as snug as it should be. Might have been worn or low quality, but I believe the second cross they had was ONLY metric and I remember it fitting the lugs perfectly.
So, what do you guys recommend?
