3M DIY temp (1 yr) clear bra spray??thoughts?
I was just going to post a topic on this as well. I would want to see how it looks on the bumper as well, the video does not show that application which would seem to be much more difficult.
This is a spray, SO, how do you not get it in between panel gaps? or do you have to mask each panel where it ends? that could be a PITA.
(masking the lights would be a pita too...unless this can go on lights also...i think it could)
Their demo video only shows a horizontal surface - hood. Will it run when sprayed on vertical surfaces like bumper and fenders? (esp. because you;re supposed to layer it withOUT letting previous coats dry...)
I guess not, it doesn't LOOK like it would, but just curious...
Sprayed it on the nose of my Camry yesterday......setting outside in the sun today curing.......we will see how it goes.
mine is on its way from amazon.
How did you spray where panel gaps are? did u mask each panel?
Did u notice any of the stuff getting in between the panel gaps?
Any pics?
