You will hear that the cool down is no longer valid for late-model vehiclesAlways use full synthetic, never go longer than 5K miles on an oil change, and let the engine idle for 10 seconds before shutting it down...have you heard similar?
My fusion does this also.....I have heard idle down as well. But when I shut down the wife's Kona, I hear what sounds like an electric motor running for about 30 seconds. I was assuming this was running coolant around in the engine to help cool the turbo.
^^^ this ^^^Of course, cool down happens in typical driving, as most drivers don't go from highway speed to parked in 3 seconds. The time it takes to park is sufficient.
I say yes to the first 2, but at least my opinion on the third, you need to make that longer IF you were aggressive with the throttle before shut down. If you were driving like Grandpa then it is ok. If you came off the hwy/towing/ or just raced a WRX, there is a sliding scale to that time.Always use full synthetic, never go longer than 5K miles on an oil change, and let the engine idle for 10 seconds before shutting it down...have you heard similar?
There will always be varying theories, but I've done those very things with my current ride for over 8 yrs now and will continue doing so. May never be any way to actually prove things making any real world difference, but peace of mind as well as long term vehicle use with no actual mechanical issues/failures speaks volumes.Always use full synthetic, never go longer than 5K miles on an oil change, and let the engine idle for 10 seconds before shutting it down...have you heard similar?
Yep, I heard that many years ago. In the 80's, in fact. My Dad was an engineer at GM and we had company cars. An fellow engineer and friend of his who had a turbo Sunbird/J2000 loaned it to us for a short time. He told me he ran Mobil 1, changed oil frequently (every 3k at that time) and told me to idle it for 1 min before shut down to cool the turbo's bearings, unless I was driving very gently before then. But he knew I wouldn't be driving it gently. That little car was a hoot. I think it had about 165hp, IIRC, which was pretty good for a 1.6 or 2.0 liter 4 back then. I believe it was 0-60 in just under 7 seconds, which was also quick for those days. I remember it being a pretty fun lttle car.Always use full synthetic, never go longer than 5K miles on an oil change, and let the engine idle for 10 seconds before shutting it down...have you heard similar?
Even though I don't I own a BMW Mini, I follow a Mini turbo rebuilder and he talks about a good # of turbos come in with an early death from being all "coked up" (ha ha) from people who don't practice proper turbo cool down care and proper oil choice. He says BOTH are critical for long life of your turbo.There will always be varying theories, but I've done those very things with my current ride for over 8 yrs now and will continue doing so. May never be any way to actually prove things making any real world difference, but peace of mind as well as long term vehicle use with no actual mechanical issues/failures speaks volumes.
This is my routine on my 17 Regal GS 2.0T but i'll let it idle for a minute.Always use full synthetic, never go longer than 5K miles on an oil change, and let the engine idle for 10 seconds before shutting it down...have you heard similar?
