wemay
Site Donor 2023
Good video on the earlier version...
The same with the 200k van, it never leaked that I could tell but the pressure sensor was bad so it was due for replacement anyway.The oil filter housing is fine if you dont use a 1/2” drive ratchet and crank on it. 150K on mine, I’m the only one who touches it. And I’ve never used a torque wrench on it.
The 3.3 and 3.8 pushrod engines have a good reputation.The last good V6 Chrysler made was the 3.9L.
Agreed - their '60s V8s, and of course the Slant Six, were very tough.Chrysler engines are typically pretty good, the 2.7 being an exception...that thing was a real turd.
2017 Pacifica 3.6L with 90k miles. Not a single issue. I use mostly synthetic 5W30 and change every 5000 miles religiously. I really like this engine. The 8 or 9 speed transmission is GARBAGE though. Terrible shift quality with lots of banging , noises, and just terrible.
The 6 speed transmission I had in a Town and Country was way superior.
Where did you get the oil changed? It was most likely overtightened repeatedly and that will cause the leakage. I’m at 78k miles and it is bone dry in there. All changes done by me though and I never torque the filter cap, just stop when it touches the housing.I’m at 95,000 miles now. I have the dreaded oil filter (oil cooler?) housing leak on top of the manifold. The plastic oil filter housing has warped and is leaking oil.
Thanks for that link.
Same here at 9.5 years/85K.Where did you get the oil changed? It was most likely overtightened repeatedly and that will cause the leakage. I’m at 78k miles and it is bone dry in there. All changes done by me though and I never torque the filter cap, just stop when it touches the housing.
Any reason they shouldn't be like a spin on can filter, firmly hand tightened plus a little more? There's an inch worth of heavy threads and a nice new pliable oring there. They put that huge nut on top and psychologically you think man, I'm gonna turn it til it squeaks.
I’ve done every oil change . Oil filter housing has never been over tightened. It warps underneath the manifold away from the oil filter housing. Pretty common issue according to interweb.Where did you get the oil changed? It was most likely overtightened repeatedly and that will cause the leakage. I’m at 78k miles and it is bone dry in there. All changes done by me though and I never torque the filter cap, just stop when it touches the housing.
What do you mean by “never been over tightened”? Never went over the specified torque? Or you stopped once the cap touched the housing?I’ve done every oil change . Oil filter housing has never been over tightened. It warps underneath the manifold away from the oil filter housing. Pretty common issue according to interweb.
Our last few promasters we sent in for oil cooler leaks to be covered by warranty were repaired by just installing new seals. The service department told me there was a new TSB issued that for any oil cooler leak to be covered by warranty, the shop has to first replace the seals, clean, and recheck for leaks.What do you mean by “never been over tightened”? Never went over the specified torque? Or you stopped once the cap touched the housing?
I know it’s a pretty known issue on various forums, but the cause is a not exactly that clear. I know it’s easy to blame the plastic, but I don’t think it simply warps by itself. The intake is also plastic and doesn’t do that.
I believe the torquing of the filter cap, even to spec, contributes to this issue quite a great deal.
Below is the passage and seal layout. The ports simply sit on top of each other. So any twisting force to the main body, which is exactly what happens when applying torque to the cap as I tried to picture in the second pick, will start lifting the seal. Since they sit flat on the mating surface, it doesn’t take much to have a leak since it’s all under pressure.
If this was a male to female type connection, there wouldn’t be an issue.
Anyways, that’s my theory and I believe no torque should be applied to the filter cap, after it made contact with the housing whatsoever. But I don’t blame people that do torque it, Chrysler has a spec for it after all.
It could also be the case of just the seals hardening and not compensating for thermal expansion. Or most likely a combination of all of the above. Therefore I think going with an aluminum housing may not prevent this issue. That whole interface is simply awful IMO.
