24 Nissan brake release tool?
Ohio
I wanted to get a head start on a tool that will release the rear calipers on the wife’s 24 Altima SL with electronic parking brake. Does anyone have any testimony or advice for a scan tool that’ll work, as cheap as possible? I’ve looked at so many that I’ve confused myself. I’ve got a scanguage 2 that works for cvt service and odds and ends, so I just need a tool to release the calipers and nothing more. If such a thing even exists.
Keep looking on YouTube for a DIY secret for these eP-brakes as far as disengagement while doing rear brakes. Some are easier than others but most can be done without a special & expensive scanner.
Often, it’s how many times you have to press the P-brake button, or do a couple of things simultaneously or disconnect the rear P- brake clip at each wheel prior to doing any service.
I don’t know if I said any of these correctly but, I hope you get the picture. YouTube is your friend. ;)
Drums are lifetime for most lol. I can do rear pads on a Nissan in 20 minutes per side, and do it right. This whole “service mode” is new to me.
  • Like
Reactions: D60
I’m sure there’s a way without a scanner. But, things like that never work out for me.
Well I shared here my saga with scanners for Nissan EPB, TLDR is there is nothing for Canadians as yet, but Foxwell is going to have something soon, but you're in USA so you don't have any wait.
The 'redneck' method is to disconnect the EPB connector at the caliper and then supply 12V power to the metal contacts inside. If the parking brake tightens, then switch the polarity of your 12V source and it will then release. It's just a 2 wire 12V motor so making it go clockwise or counterclockwise is just switching the + and - wires.
  • Love
Reactions: D60
Power Probes are really handy for this.
Unrelated, but KL Cherokees let you put the rear brakes in service mode from the touch screen. What a concept!! (I'm no fan of recent Jeep products but credit where credit is due)
