Well, after three drain and fills the last one finally came out a dark red, based on a calculator, I'd say I've replaced about 85% of the fluid. Driven approximately 4000 miles since the first drain and fill and the transmission shifts like it's brand new.
The car has about 131k on it, the manual states every 60k for severe service, I figure 3 drain and fills replaces most of the fluid, so every 20k will gradually replace it over the 60k span. Fluids cheap and a drain and fill is almost as easy as an oil change with my hose funnel. Is 20k too often? Plan on keeping the car until it irreparably fails the strict MA inspections (ie rusts apart).
