2025 Chevy Tahoe 6.2L - metal in factory oil filter
wwillson
Staff member
Colorado
This 2025 Chevy Tahoe was built in April of 2025, well past the June 1, 2024 date that GM says they fixed the manufacturing problems with the 6.2L gas motor. I changed the factory oil and filter a while ago, cut the filter and let it drain. The factory oil and filter had 2,000 miles when changed. Always cut the element out of your filters, as you get a lot of insights to what might be going on in your engine.
The below pictures of the factory AC-Delco filter element cut out of the filter and stretched out to get good pictures. I will keep this element as long as I have this vehicle, just in case. To me the amount of metal in the filter is disappointing and hopefully it isn't a sign of trouble. Time will tell.
I don't know I would be worried too much, the volume of metal pieces isnt alarming, the large size of some of them are pretty unusual though. I'll try to remember to save filters to cut open from work from first services, it would be good to have more for comparison on this board.
I did not see any metal on the L84 5.3 filters I opened at 500mi and 2,500mi. I am starting to think the 5.3 is the sweetheart of the bunch.
I’m on my 4th and 5th 5.3L … no issues with any of them …
Have always done an early change - 500 to 1000 miles …
Generally, it's not uncommon to see some few break-in and machining remnants in the first FCI. Though I must admit that's the most I've seen in a filter in a long time.
I have to wonder, if that's what was caught by the filter, what didn't get caught? Where else has it accumulated? How much and how large is the stuff at the sump pickup tube screen? What got ground up by the pump? I'm not saying I have the answers; only curiosity about what's going on in there.
