Got a waiter oil service this morning.
First removal of the air filter is a job. You have to use a 7 mm open end wrench to get to the clamps on the air intake.
They you must remove a cross brace with T30 torx bolts.
Then the oil filter can't be removed until you remove 2 oil feed lines for the turbo. Then put it baack together hoping there's no leaks from those 2 lines.
