2022 Subaru wrx black Tokyo Roki filter (used) C&P
I leave the oily gasket on when cutting, helps reduce friction and doesn't mar-up the cutter. Yes, cranking down on the cutting wheel with too much pressure is not the way to go. Go easy and take more rotations to cut through the can.
I'm not a fan of keeping the gasket on ever when cutting. Filter gaskets when not pulled off most Gaskets are deformed and cutter will walk up and down the gasket. Pulling the gasket off makes the cutter run true and flat make a easier time cutting it's direct on base plate and can in my opinion.
Does the WRX use a shorter filter than other Subarus? Hood clearance a factor?
Yeah, the filter sits higher than on the non-turbo FA20 due to the oil cooler. If you use a filter taller than ~3.5", the hood insulation can get a bit melty.
