Wix 57055 C&P "Disappointment"
Looks like recall material. FWIW, I have 8 on hand, Jan 23 MX production, and they look fine.
I would not be comfortable with those louvers. Below looks messed up too.
First time ever C&P. Got a cheap $19 cutter on Amazon and it's great. Anyways here's a Wix 57055 filter removed from my 2021 2.5L Subaru Outback. 2,650 miles from January to June with Mobil 1 Advanced Fuel Economy 0w-30. To start off the louvers are atrocious. Barely a hairline open and many of them completely shut. Is this a common QC issue on Wix? Bypass valve has a sloppy/ stretched gasket. Media itself was rock solid. End caps were glued solid with practically no excess glue seen. ADBV rubber was in good condition. You know I think this filter was operating most of the time in the bypass mode due to louver issue. Just my speculation. Especially in the very cold weather this filter saw in MN winters for the first 3 months of the year. I got 2 more Wix filters with same part# in my stash I have to inspect but these filters are mostly all 1-2 years old from previous online orders.
I don't think it is so rare with M&H..
Here is another Purolator with the same issue :
https://www.mustang7g.com/forums/threads/purolator-boss-oil-filter-quality-control-problem.164928/
So, It doesn't look great, but the louvers mostly are opened. I am eilling to bet more oil goes through that then you think. I dount the filter was in bypass.
I posted a virgin C&P several weeks ago on an FVP filter. Louvers looked the same. Pulled off the media from center tube and posted pics with a flashlight. The filter was fine. Looks can be deceiving.
To be clear, I don't use filters with louvers. I use PG or OEM 90% of the time.
Toss that and other two in the tall grass. Shoddy construction. What went on and in?
Amsoil
In: Amsoil XL 5w30/ Amsoil EA15K13 filter. I have a 6 pack of PG PG4612EX I plan on using after. While not 100% correct bypass psi spec for my engine 14-17psi is better than 11-17 psi of the Amsoil filter. Eventually I’ll find a case correct Subaru PG EP filter when they release later this year.
  • Like
Reactions: GW.
Yeah they don't LOOK great. But the pictures do make them LOOK worse. Some are open. None look shut completely as claimed.
Remove the media and post more pictures - I am not judging so quickly.
Here are some pictures. You’re right that they weren’t completely shut. However some were barely open. Looking at these pictures makes me feel better about the filter performing in colder weather. Not great but probably wasn’t bypassing as much as I thought. I checked carefully after cutting the media and noticed the baseplate wasn’t glued all the way.
Amsoil
The MGSL and CQP have the correct bypass setting and are Subaru specific. Note the CQP is the shorter version.
I’m waiting for a 12 pack case to drop on eBay for MSL 😂. PG EP is listed new on their site but not really out there yet. I’d take a 6 pack of those if posted.
  • Love
Reactions: GW.
Kinda sorta, but how does oil "pass" through the filter right before many slots?
FYI: I am not saying this filter is GOOD. I am saying I need more pictures. Don't confuse the two.
Right? Yes, the filter certainly LOOKS bad. But as you said, looks and proper operation do not always require the other to be pristine and still function properly.
Add up all the area of the hundreds of louvers, stick 60psi on the other side, and you’d be AMAZED at how much oil will pass through that tube. Also, the bypass is 27psi on those filters, I believe. That is a LOT, so I highly doubt the reality of that filter’s performance is anywhere as bad as your assessment.
Not throwing stones, just talking @Nuclear_42 off the ledge. The can is nice and clean with no grit, and if you did a used oil analysis and nothing was greatly amiss, I’d bet the cost of that filter your engine didn’t suffer any permanent damage above and beyond normal wear.
BTW, don’t throw those 2 new filters away, I will happily use them on my Impreza. I’ve only got about 5 NAPA Gold 7055s left. PM me and I’ll cover shipping 🤩
Look at the light. That is NO obstruction.
Lousy made, could be MUCH better. Sure.
I agree. I hadn’t gotten to the light pic yet when I had posted, but that proves our points.
This kinda feels really similar to the endless threads we’ve had where people “feel” the number and size of inlet holes is just waaaaay too big relative to the center tube thread size, and that it’s restricting flow through the filter and going to destroy their engines. 🤷‍♀️
Appearance and performance are not inclusive requirements no matter how much we’d like them to be. Sometimes, (maybe after 5 gallons of home-brewed beer!) even ugly gets the job done. 😳
it would be interesting to see a test of a filter like that, on flow rate , i have a handful on my shelf just like that one , that i wont use ,or maybe wix does not want the the oil to pass through too quickly or it wont filter as well😒
Louvers need to be inspected before installation ... always.
  • Like
Reactions: GW.
This, they never look great from above.
They do if they are opened up well like they should be. If they looked even half choked down by looking down the center tube they get a reject from me. Solution - buy filters with holes in the center tube or an Ecore center tube.
Assuming the louvers are opened, the pressure drop across that filter when using a PD pump is probably pretty minimal. Other parts of the lubrication system will be significantly more restrictive.
Choked down louvers are not planned by design to enhance functionality. An ideal filter would have near zero dP vs flow, but of course that's impossible because of fluid dynamics physics.
It's about the dP across the filter itself due the the flow rate and oil viscosity, regardless of the dP across all the other components of the oiling system. If there is too much dP across the media and center tube, then the bypass valve is closer to opening. If the louvers are really choked down, it's going to raise the dP across the bypass valve and could make it open sooner and more often compared to open louvers that don't increase the dP.
