All, coming up on my 50k axle/t case service. Manual doesn’t quite call for it yet but I tow a lot and every 50k is a nice easy interval to remember.
I was aiming to stay with factory fluids until the warranty period was up but you can’t get any Mopar fluids right now with the strike.
Front axle specs 75-85 GL-5 (dumb and 75-90 would probably work fine)
Rear axle specs 75-90 GL-5 meeting the current Chrysler standard
T case specs Mobilfluid LT (or the re bottled Mopar quart).
Considering switching the axles to redline all around. I may just bite the bullet and order a 5 gallon pail of the Mobilfluid LT and I’ll never need more again in the trucks lifetime. Can be had for 150-200 for the 5 gallon rig.
If anyone has any feedback on the redline in the axles info would be much appreciated
If anyone has a trick to get the Mobilfluid LT by the quart that would also be much appreciated. Have done plenty scouring so far and haven’t found a quart solution that’s a true cross reference to the Mopar/Mobil.
