2021 GM 5.3L L84 Engine, Best Fuel Additive to Use?
SE Michigan
Looking for the best fuel additive for the 2021 L84 5.3L Engine. I have used Chevron Techron but their are alot of options out there. Wondering what my engine will respond best to.
There was a study done, I forgot who it was by. Anyhow, the top two products were #1. Red Line SI-1 and #2. Chevron Techron Concentrate Plus out of a list of 13 they tested. I will attempt to put a couple Amazon links on here for you.
https://www.amazon.com/Red-Line-601...653&sprefix=Red+Line+SI+1,aps,145&sr=8-1&th=1
https://www.amazon.com/Chevron-Tech...90781&sprefix=Chevron+Tec,aps,150&sr=8-2&th=1
99% of the time I use Costco
Then you will be fine. I use mostly Costco in my Civic and I have never added any fuel system cleaners. I bought the car with 130,000 km on it and now have 303,000 km. I’m not sure if the previous owner used any, but even if they did, I’ve gone 173,000 km without it and the engine is running perfectly.
When you say Valvoline Restore and Protect Fuel System Cleaner for their new tech what do you mean by that?
PEA is proven and works great, Redline has the highest concentration of PEA. Along with maybe BG 44K at similar levels.
Valvoline’s product does not utilize PEA and rather has whatever new cleaning tech they have discovered, similar to their Valvoline Restore and Protect oil.
Available in store at AutoZone only so far, but online ordering should start “soon”
