I doubt Overkill will attempt this, or even consider it
No, I won't, and I'm not. The ECM would also stroke-out because this would definitely throw a viscosity CEL.
This is also wild speculation about:
A) that the UOA PPM figures directly correlate with wear (they don't)
B) that an insanely heavy oil will reduce that figure
C) that B would result in lower actual wear, something that is only discernible via tear-down.
My 6.4L, on 0W-40 (so, considerably heavier, now, caveat that it has lower mileage and arguably probably still breaking-in) its most recent UOA was 4.93ppm/1,000 miles.
This engine family, the GM small blocks, the Ford large V8's...etc, they all throw more iron per 1,000 miles than most of the small bore V and inline engines.
The 3.699ppm/1,000 miles from this run compares well with these:
2016 Corvette, 20W-50, average
6.04ppm/1,000 miles in the most recent run:
118 miles, 2.2 engine hours since oil change. Last UOA is here. UOA history of this vehicle: https://bobistheoilguy.com/forums/search/2149941/?q=Z06&t=post&c[child_nodes]=1&c[nodes][0]=3&c[title_only]=1&c[users]=Emperors6&o=date&g=1 Notes from slip: "Took oil sample with vacuum pump through dry...
bobistheoilguy.com
Previous run was 6.12ppm/1,000 miles
2013 Cadillac CTS-V, M1 0W-40,
3.57ppm/1,000 miles:
Previous UOA is here. UOA history for this vehicle is available with this search: =1&c[nodes][0]=3&c[title_only]=1&c[users]=Emperors6&o=relevance&g=1']https://bobistheoilguy.com/forums/s...le_only]=1&c[users]=Emperors6&o=relevance&g=1. Switched to a shorter OCI of 5k/6mo (approximately)...
bobistheoilguy.com
2010 Land Rover Range Rover, LM Synthoil 0W-40,
4.39ppm/1,000 miles:
This is of my 2010 Range Rover with the 5.0 Naturally Aspirated V8. We are the original owner, it's been running the same viscosity (5W-40/0W-40) for the last 10 years and we have never run an interval over 6k miles. I started doing these analysis after the vehicle went over the 100k mark, it...
bobistheoilguy.com
2022 Ford F-250 7.3L, 5W-20/0W-40 mix,
3.25ppm/1,000 miles:
Oil in use one year and a few days. Towards the very end of interval was ~3,400 miles over 5 days of towing a 7,500# (total) U-haul trailer with vehicle to Moab from Alabama and back. (FWIW, averaged 8.1 mpg on trip out and 9.1 mpg on trip back. Engine worked pretty hard.) Day after trip was a...
bobistheoilguy.com
2007 GMC Yukon 6.2L, various oils, various results,
4.8ppm/1,000 miles on 5W-40:
2007 GM 6.2L w/186k, HPL PD 0w20 w/3400 In Dec 2022 I sent a virgin or baseline sample of this oil to OAI. See the "BL" sample. Recently I sent a uoa sample of this oil to OAI to do a "value" analysis. See result #7. Oil has 3400 miles, 67 hrs mostly hwy, avg 50+ mph. The vehicle is a 2007 186k...
bobistheoilguy.com
200? Honda S2000, Penrite 10W-40,
3.13ppm/1,000 miles:
First UOA on my S2000, changed early due to hard driving including one track day. Car has approximately 150,000km on the clock (90,000 miles) with 1000 miles on this oil. Short OCI conducted as I was eager to check up on the motor following valve retainer replacement and following the vehicle's...
bobistheoilguy.com
1995 Jeep XJ w/4.0L I6, M1 10W-30,
9.00ppm/1,000 miles:
I am a new member, but I have been using the information on BITOG for a few years. Recently, I bought a '95 Jeep XJ with about 95,000 miles. Since owning it, I replaced the timing chain, rear main seal, & water pump. Considering the new internal parts/seals, the Fe & Si ppm are not going to be...
bobistheoilguy.com
2019 Kia Stinger, Motul Sport 5W40,
4.00ppm/1,000 miles:
Previous thread here for where I asked questions: https://bobistheoilguy.com/forums/threads/oil-recc-19-stinger-3-3tt-with-track-time.351806/ Based on track-shop's advice and not great inventory of other oils, I decided to try Motul 5W40 Sport (got a pretty good deal on Amazon). Here's the...
bobistheoilguy.com
2016 GMC Suburban 5.3L, AMSOIL 0W-20,
3.02ppm/1,000 miles:
Seems our Suburban does way better using E85 100%. That and turning off the active fuel management made a difference. Water is way down and is a good indicator on using E85 as well as fuel dilution.
bobistheoilguy.com
Previous run was
4.33ppm/1,000 miles
