No changes from last time... Same normal routes but there is some heavy towing this go around as well as several hours on the beach in cape hatteras. Saw the highest sump temps yet (240F momentarily which is absolutely nothing for modern oil imo) and then right back to the 180-190F range. Pulled around the same OLM % which was 7. No makeup oil added. Lots of idling too. Delco cartridge as usual.
Not going to change anything. Thoughts?
Edit: didn't bother with TBN this go around mainly because I forgot to check the box. Oops.
