I did a mid-OCI UOA check on this oil that I posted last month. This oil has several track days on it with triple-digit mph sustained use as well as a mountain hooning run with elevated oil temps. This oil was also put in just before I swapped in a new larger turbo and some other associated bolt-ons (larger intercooler and charge pipes/hoses). I've included my tracking tables/graphs to-date. This oil definately saw the most viscosity drop as a % of the VOA I did of any of my changes. Wear metals remain low but did see a slight tick up from the new turbo. Silicon also ticked up likely due to sealers etc. from the new hardware and not the K&N filter on my open intake. My current fill is Mobil 1 0W40 so will be interested to see how it fairs after a similar 5-6K run in terms of viscosity shearing. I have a more mild track day on the new oil but won't likely have as much severe use as the subject oil of this post. I like the Molygen due to the tungsten/moly friction modifier compound it contains but I don't think it holds up quite as well from a viscosity standpoint as the Leichtlauf High Tech I was using which I did boost with some Ceratec and MoS2 - really just need to change it out sooner is what that tells me. I get my oil kits from FCP Euro and use their lifetime replacement so these are free to me now that I get my return shipping refunded b/c I use Paypal.
