2016 Mazda 6; maintenance suggestions?
Looks like I’m taking over maintenance duties on one of these. It’s not a Speed. I have zero idea on mileage or maintenance history although they did tell me the oil change has less than 500 miles to go. Family member is having issues and this will be one less thing for them to worry about.
I’ll be changing oil and filter very soon, I’m assuming there’s a gasket or crush washer for the plug, and I’ll take a look at the air filter because I’m sure it hasn’t been changed in the last 4-5 years. Any common issues with this gen of 6? Do they have a programmable maintenance reminder? This person definitely shouldn’t go beyond 5000 miles for an oil change due to short tripping and not driving more than 20 miles for work and then going home.
One last thing, what coolant do the Mazdas use? Probably should dump what I can and refill. Is there a bleeder valve to purge the air?
Hey there, I have a 2016 Mazda6, purchased it new, and I can't speak to coolant changes as I still need to do a flush (gasp) ... all tests of the coolant have come back perfect (acidity/litmus paper and visual inspection). Still should get done at the 10 year point. I will use the Prestone funnel tool which helps significantly. The vacuum tool/technique might be a good way to go too.
I ran Mazda moly 0w20 for the first 100k or so, then ended up switching to Costco Ow20 to match my Yukon.
Yes there is a crush washer but honestly it isn't a big deal, I have reused with no issues.
Depending on your trim, there may or may not be a maintenance reminder. Mine is the base spec and has no reminder.
I have done 7.5k intervals up to about 175k then I switched to 5k, filter replacement every other oil change.
Don't forget the cabin filter, it's an easy change behind the glovebox. Just have to remove the shock absorber/damper that connects to the glovebox.
Coolant is FL-22, the Mazda p/n is 0000-77-508F-20. The crush washer for the drain plug p/n is 99564-1400.
Great cars, don't see a lot of issues beyond basic maintenance. Keep an eye on the belt tensioner, they are hydraulic and we do a fair amount of them.
Is the same crush washer used for the transmission drain and fills?
I don't want to have to drop the belly pan to find out....
Most everything you want to know regarding maintenance is covered in the owner's manual.
If you can't find it in the car, look online.
Will probably a month before I touch it, hopefully sooner. If it’s in the car I’ll bring it home and break out the post it notes for bookmarks.
FYI: there also are plenty of forums out there dedicated to the Mazda 6. That community is very helpful and is always willing to help with any questions you may have.
The 6 was a sleeper in the Mazda lineup. Crazy that it became more popular after Mazda discontinued it.
I recently bought a '21 and I haven't found very active communities for it, actually. The one website forum I found was very stale.... Most activity is a reddit forum, from what I've found.
What forum(s) are you speaking of ? I'll definitely check them out.
How many miles ?
ATF needs replacing. Drain and refill very easy.
keep it simple,
coolant - i believe Mazda does a 55/45 mix of FL-22
transmission drain and refill - Castrol Transmax ATF is reliable stuff
any brew of 0W-20 brew will do
i personally become a big fan of the extractor method, i don't like messing with drain plugs and crush washers these days. if you're doing 5,000 mile oil changes any filter will cover that out there. don't get hung up on the no adbv filters the adbv is redundant on the skyactiv engine and aftermarket filters that fit will have one and cause no harm. if you really want to stick with a filter that omits the adbv wix has one or go oe.
I've got a 2017 with the M6 and am about to do the coolant for the first time. I won't use premix as I like to do multiple drain and fills with RO or distilled water, then just add concentrate to get it back to a 50/50 (or 55/45) mix. No way to do that with FL-22 premix so I'm going with Zerex Asian concentrate, which from everything I've read, is an excellent substitute.
  • Like
Reactions: wlk
keep it simple,
I won't use any aftermarket "one size fits all" ATF on these transmissionmissions... the only aftermarket ones that work properly are Aisin ATF-FZ (crap) and Ravenol ATF-FZ (best)... the Ravenol is most expensive and not worth switching to unless you pay someone to flush out all of the original fluid and switch to it... the Mazda OEM ATF-FZ (made by Idemitsu, but no aftermarket Idemitsu is available) is more expensive than the Aisin but not by much and is much better than the Aisin
Motorcraft VC-10-A2 is a concentrate and is a real FL22 from what I read here long ago
yup... they're so common that there's a TSB for it
the first sign there's a problem, you will hear a faint "marbles in a can" or some sort of dieseling sound... you can confirm this by visual inspection to see if its caked by grease... if it looks clean, rev the engine while parked and you can probably hear it
change it ASAP if the belt is still good and you want to save the belt from getting destroyed.... if you have to limp on it, then launch the car in manual mode and shift it at higher RPM before putting it back in "D"... driving strictly in "D" it will try to shift into 2nd gear ASAP and lug the motor at low RPM to save gas, but it also puts a high load on the belt and that's how you can kill the belt with a bad tensioner quickly
My belt snapped at 75k on a hot summer day 15 miles from home. Fortunately the water pump has its own belt and I had a new battery so I was able to drive it home. I don’t know if the tensioner caused the failure but I went ahead and replaced it anyway.
For coolant I used the Peak Asian Green concentrate.
I notice absolutely nothing different with rock auto sourced aisin atf fz vs Mazda fz. I used Mazda fz for the first couple drain and fills and aisin for the last 2 if not 3. I’m at 125k miles. Only difference was aisin is about half the price and I’m sensitive to transmission shift quality.
IIRC, the deterioration and UOAs of the aisin wasn't as good as the mazda... if you're able to find a good discount, the mazda stuff doesn't cost a lot more than the aisin
or do the "buy once cry once" thing like I did... pay the dealer to flush out all of the factory fill and put in ravenol... afterwards, you can do a drain and fill with extended drain intervals without problems... the ravenol shifts way better than even a brand new off the showroom transmission with the factory fill... no TCM relearn trick needed... on its worst days/weird conditions, it shifts the same as the mazda fluid, but otherwise it normally shifts better
