I've got a quick question, maybe you guys can help me out.
My wifes Acura has a maintenance minder, basically an oil life monitor. But it also reminds you of other maintenance items needed, like cabin air filter, transmission and diff fluids, etc. Basically when the oil life gets low, it throws you a code like A2 or B3, you look up the code, and get the maintenance done.
Most of the ones we've had are just oil, or oil and air filter etc. We've only had one so far that recommended a diff fluid change as well. Once you do the change, you reset the monitor and it goes back to 100% oil life. Fairly straight forward.
Now here's my question, this fall I wanted to get an oil change in before it got cold, so I changed the oil a bit prematurely at around 30% oil life left. I reset the olm after I did this, but I reset it before it got a chance to throw a code and tell me what maintenece was due. I'm concerned that by reseting it prematurely, I might have wiped of one of the major maintenance items before it got to give me the code.
IWhat do you think? Did I mess it up? Is there any way for me to check this?
Thanks.
Thanks.
