I have read conflicting answers on other forums but know I will get the straight scope here.
I always change oil before MM tells me to and then I reset oil life to 100% according to instructions in the Owners Manual. By doing this, will the MM give me other maintenance reminders at the correct intervals? I ask because some say that you must let Acura reset with a special tool. If you reset according to the OM like I do, some say the MM is reset to zero miles and I will never get codes for such items as ATF or rear differential change. Thanks.
