2016 Lexus RX350 Oil Change change
Chadds Ford
Changing the oil in my 2016 RX350 for the second time since I've owned it. First OC I used Mobil 1 0W-20 Advanced Fuel Economy and a Toyota OEM filter.
This time around I'm going with PP and a Super Tech filter. I think it's pretty much all the same with 6000-7500 mile OCI.
Just changed the oil in my wife's 2016 ES350 with the Mobil 1 Advanced Fuel Economy 0w20 and a Wix filter.
Neither vehicle see any tough duty...trailers, off road etc...
The 2gr-fks would also be happy with Mobil 1 5w30 and a trd oil filter that you can change every other time. The cartridge types are a PITA and messy
Had that engine in my 2009 V6 Venza.
Found a screw in filter drain nipple worked so much better than the snap in OEM version.
The screw in nipple from an aftermarket filter package allowed a slow release of the oil.
Once you use that, the oil changes are almost enjoyable and relatively clean.
I leave the disk alone and just turn the whole assembly slowly like i would a spin on filter. Let it drain once it starts seeping and then remove the whole assembly with no mess at all.
That's what i do as well, makes a little bit of a mess but quick and easy, I just clean the housing up as the oil pan drains
I just let the Toyota cartridge filter drain as others have posted.
I buy the Toyota filters on line; they are pretty cheap.
I think Walmart has them as well.
The Lexus RX is a great vehicle.
My buddy bought one with 150,000 miles here in Indiana, drove it to Alaska, and sold it for a small profit (not including his travel costs but more than he paid for the car).
We have a 2013 and use the factory filters from Walmart and Mobil 1 Advanced Fuel Economy or Mobil 1 Truck and SUV, both in 0W-20. Great motors and transmissions.
